FoMoCo remote valve explode
riveroadrat
Would anyone out there have an exploded diagram of a C5NNB929K remote valve? I have looked all through CNH partstore at different models and years and cant find this valve. They made single and dual versions of this valve. I need orings for the spool and I dont see a place to put an oring on the spring end.
C5NNB929K is the casting number for the valve body casting. It is not necessarily the part number for the entire valve, or even for the valve body. Casting numbers are not usually part numbers, but there are a few exceptions. Are there any other numbers on the valve?
Not certain, but believe it is covered (no part numbers) in the I & T FO-20 manual.
Dean
Go to Messicks put in 3000 then hyd section go down to 05G02 and 05G02 pics. There is 2 -113 orings used. Think that's what your looking for.
