instrument cluster 73 Ford 2000 3 cylinder gas
dirtfan1
I am in need of a wiring diagram for the instrument cluster for a 73 Ford 2000 3 cyl gas. cluster was unhooked and wires were cut before i got the tractor so i need to know what wires go where. RPM needle is broken so i'm not concerned with that. i just need the temp gauge to work most importantly and the fuel gauge to work.
thanks in advance
This is out of my 3000 manual. I think they are the same.
Someone please correct me if its not.
(quoted from post at 09:32:39 03/17/18) This is out of my 3000 manual. I think they are the same.
I dont believe this shows the ground wire on the back of the cluster iirc.... It also must be added for the cluster to work correctly. And iirc,, its a black wire...but I have slept since then. Maybe someone else will chime in. Thx.. Bill
on second thought i can't read this. does anyone have anything simpler? i will post a pic of the back of the instrument cluster if someone can tell me what wires go where. i'm very sorry but this will have to be dumbed down for me.
This is what my book shows looking at you photo
#1 connects to the temp sender wire
#2 connects to #6 on the voltage stabilizer
#3 connects to the ground wire
#4 also connects to #6 on the voltage stabilizer
#5 connects to the fuel tank sender
#7 connects to key hot wire
