Ford 600 3-point hydraulics problem
aftrhrtv
New User
This message is a reply to an archived post by karman1970 on September 03, 2017 at 13:31:07.
The original subject was "Ford 600 3point hydraulics problem".
Does anyone know if this lift issue ever got fixed?
My 640 is doing the exact same thing. -- It works well for the first couple of minutes and then it starts hiccupping and will not lift but only a few inches.
What was the solution to this one?
Ford 640 lift hiccups and stops working after warmed up
Hiccups are result of worn piston oring and backup washer. Internal mechanics correct the drop in the arms and move the piston back into position. It keeps repeating this and the heavier the weight on the arms, the faster the drop. Type ZANE in the search and hit it twice. It will pull up old posts on the subject. He sells a kit that makes the setting job easier and also has a kit for a worn out cam pin. I think he has a lengthy post on the subject.
Thanks so much for your kindness and response, RRR. I will search ZANE as you suggested. Have a great day.
Does anyone know how to reach ZANE? Or does anyone know where to get the cam follower pin and instructions that ZANE is talking about?
TIA
(quoted from post at 03:36:54 03/16/18) Does anyone know how to reach ZANE? Or does anyone know where to get the cam follower pin and instructions that ZANE is talking about?
TIA
Heres his website, http://www.bramblett.com/zane/
