601 lock brakes together
Jofeffi
New User
How can I lock the 2 (RH and LH) brake pedals together on my 601 Workmaster? I don't need the individual braking so would like to link the 2 together so that pressing down on either will apply braking to both rear wheels.
Pedals are close together. ..just stomp both. Should
be a lock on each side to use as parking brakes, if
that's what you want.
I have never seen or heard of one. You are on new ground. You will need to design it and build it or get it built. I will consult on it for a percentage. Millions to be made here since it will be useable on all of the XX0s, XX1s and early X000s.
Are your feet so small that they can't press both at once?
I used to have size 11's and over time they have shrunk down to 10-1/2's, and I can easily press both simultaneously.
On the 3 cylinder thousand series the two pedals are closer together and can easily be pressed simultaneously by even the smallest foot. They also do have a sliding pin that locks them together. That is because only the left pedal actually has a parking brake pawl/lock on those, so you need to pin them together to apply both for parking brake purposes, but I don't ever lock them together any other time. It's too darn convenient to press one or the other when you want the tractor to turn faster.
