Steering turns right but wheel just spins and walks up the shaft when turning left. From all I have read, this is indicative of top bearing failure.
I've seen very detailed instructions on how to rebuild completely and also have the manual.
I would like to know if there is an easy way to just replace the top bearing and race without having to pull the whole unit from the tractor. Can I just remove the top assembly? If I have missing rollers in the top bearing then I guess it gets more complicated?
Thanks!
Thanks!
