Fordfarmer
Guy on another forum is trying to figure out exactly what he bought. Hood decal says 4100. Has twin 3-point levers, double reduction rear end, diesel engine, 6-speed transmission, swept-back front axle, and dry air cleaner/low mounted headlights. Also has yellow paint under the blue. The stamped numbers he's found are 3G19R (probably a B, not an R), 390360 (at least the A,B, or C is missing, maybe more?) and D5C12K. I haven't been able to match it to anything in my books. The twin 3-point levers and dry air cleaner and tin style say x600 series. As far as I've been able to find, both the 4100 and 4600SU were 8-speed/independent pto only. The D would indicate a 4xxx variant, and the K should be a 6x4 manual reversing, right? He says 2 reverse speeds.
