'62 2000 4 cylinder carb tips
Carls70
Hello all,
I am going through the carb on a 1962 2000 4 cyl Ford. This is my first time in a Marvel updraft carb. Anyone have any suggestions, tips, warnings for me?
Have a kit & float on order from Steiner's.
It was last gone through about 12 years ago and recently has begun to seep fuel externally. This week it let a load of fuel into the throat and left a puddle on the ground...
I think it is an FSX 765, having trouble remembering.
Thanks! Carl[/list][/i]
They are very simple to work on. Just clean them out good with a carb cleaner, use a thin wire to clean out any jets or openings,
make sure the needle and float are set right (usually about 1/4" from the cover when held upside down, use the gaskets, make sure
that throttle body has no leaks for air to get in, and then reinstall.
