TractorLinks.com
Order Ford 2000 Parts Online
Re: Ford 2000 not starting
Sean in PA
03-13-2018 13:59:18
Is it being gravity fed from the tank through the in-line filter to the carb? The original fuel system on that tractor had a mechanical fuel pump up at the front of the engine. The fuel line from the tank went forward to the fuel pump and another line from the fuel pump went to the glass sediment bowl next to the carb, and finally a short line from the sediment bowl assembly was connected to the carb inlet.
There were originally 3 or 4 filters, one on top of the shutoff valve inside the tank, one in the top of the fuel pump, one in the sediment bowl assembly and the last one, which it might or might not have, is inside the fitting where the line from the sediment bowl enters the carb.
