cosmoline on engine parts
riveroadrat
If i rebuild a diesel motor and want to store it for a while would it be okay to coat all of internals of the block with cosmoline? will it just breakdown once the motor is fired up and running?
I did that about 45 years ago. Oil dripped off the new cam and when I finally got it running the cam self destructed. I now use oil on everything except the cam where I use grease and since haven't had any issues with storage before start.
cosmo can get pretty hard after years. I think I would coat the innards with assembly lube or red n tacky grease.
save the money on the cosmo and use if for your guns that you may have to soon bury. :(
Lubriplate No. 105 assembly lube. White lithium based, ans will stay soft for years. Then just do a short run, and change oil when you start it up.
Thanks all, I got my laugh for today. Not about your cam self destruct but burying the guns. What gun? My cosmo spray gun?
