Josh Tallent
Greetings all:
Quick question. On this remote valve, I think I can convert it from double-acting to single-acting by screwing out that little slotted plug on the front of the valve body. Question is, is that a lock nut behind it, and if so, how the heck are you supposed to get it loose? It's machined for a 9/16 wrench, but as you can see from the picture it only has two machined faces (so can't use a socket) . . . and as you probably can't see from the picture, it's recessed in a way that makes it impossible to get a wrench on squarely anyway. How is this thing supposed to work? Cheers!
