Ford 860 hyd pump
mj56
New User
i have a 860 ford tractor just rebuilt hyd pump put it back togeather and put it on and it is no longer leaking could some body tell me the proper way to get the air out of the pump because my lift arms are still not working It has one plug on the end of the pump but i dont know the proper steps in bleeding it thank you guys very much for some helpful information
(quoted from post at 20:08:15 03/11/18) i have a 860 ford tractor just rebuilt hyd pump put it back togeather and put it on and it is no longer leaking could some body tell me the proper way to get the air out of the pump because my lift arms are still not working It has one plug on the end of the pump but i dont know the proper steps in bleeding it thank you guys very much for some helpful information
I think ya just crack that plug open while it's running and bleed the air that way. But don't take it all the way out
(quoted from post at 23:20:13 03/11/18)
That works. Its quick and easy that way too.
You can also put a hose barb in place of the plug and attach a clear
hose to it. Remove the hydraulic fill cap and run that hose back
to the hole where the fill cap goes so the oil is returned to the sump,
then start the tractor and watch for all the air bubbles to clear the hose.
You might want to put a teaspoon full of oil in the bleed hole to create some suction action if the pump has run and still didn't prime
You can also blow a little air pressure into the hydraulic dipstick hole to push some oil up to the pump. I know this works if the lines have been drained, but if the pump is totally empty I don't know if this will do it without bleeding also.
You can also put a hose barb in place of the plug and attach a clear hose to it. Remove the hydraulic fill cap and run that hose back to the hole where the fill cap goes so the oil is returned to the sump, then start the tractor and watch for all the air bubbles to clear the hose.
If you go this route you will want to install a ball valve before the barbed fitting, otherwise the 3 point will never work. Open the valve to bleed, and watch until no more air bubbles are flowing in the hose, then shut the valve. Make sure that it is a valve designed for at least 3000 psi hydraulics, not a household plumbing valve.
