Ford 1900 rear hydraulics
Damnduke
New User
Hi, new to the forum, I have a 1979 ford 1900 and I just picked up a used Kelly 20 backhoe for it, I don't have hydraulics set up to run it, trying to figure out how to do it without making an expensive mistake. Help would be appreciated, I am a visual person so pictures go a long way, thanks!
It did come with a pump for the pto and a tank, non of it is hooked up, which wouldn't be hard to do, the guy told me the pump was slow so he had it going to his rear remotes in stead, I figured it would be easier to do it that way anyways.
Hard to believe a PTO pump would have less gpm than the remotes unless it was the wrong pump or was very worn inside. You can get a 16gpm 2500psi PTO pump from surpluscenter for under $300.00:
[u:201c31ce9a]PTO Pump at surpluscenter.com[/u:201c31ce9a]
