I just changed the oil in my injector pump and got a little oil and the rest diesel. How can I stop it from leaking fuel into the oil? Or should I just not worry about it and change the oil more often?
Also the drain and check plug threads are almost striped completely out. I don't know if anyone else has tried to fix the threads on these before. Which way should I try and fix them drill and tap a bigger size, heli coil or use a threaded insert?
