NineSixtyOne
Gentlemen,
Disclaimer! I am not an electrician.
I have a 1959 Ford 961 Diesel tractor. It is a 12 volt electrical system. I want to correctly wire an alternator to the system.
I have a NAPA 213-4011SW 12V, 63Amp Negative ground alternator. This alternator has an internal voltage regulator.
FYI: I replaced the wiring harness in 2010. I bought the harness from YT. It has been installed just like the "Electrical System Wiring Diagram 12-Volt" on page 59 of the 55 to 60 Ford Tractor Shop Manual.
Since then the, what looks like, original voltage regulator and generator has gone bad.
So this is an upgrade for this machine and I request your help wiring the alternator correctly.
Thank you for your help.
