whitcarroll24
Have a 6640 that has a new battery, new starter, and new alternator.
Also am pretty certain that it has good ground as the ground
connections have been removed and thoroughly cleaned, even
added a ground wire from battery directly to back of starter as there
was a grounding terminal there. With the battery fully charged the
starter will bog down, it will turn the engine over but it is very slowly
and it drains the battery quickly. My question is what else could cause
this? I have been told that there could be some sort of hydraulic load
that is causing this, but I do not know how to check for this since I am
not very familiar with the hydraulics on the tractor. This seems
plausible because this used to happen intermittently, but now is a
constant problem. Any help would be appreciated.
