4600 Power Steering Pump
Jacob59
Loosing fluid from my powering steering pump over a course of time. Do not see any external leaks. Could it be leaking internally and if so where would it end up?
Thanks in advance.
Also need to change the engine oil as it is now contaminated with the additives in whatever fluid you are using in the power steering. Most fluids that people use for p/s (UTF, ATF or power steering fluid) have additives that can cause harm to the engine over time.
