Dave Westlund
I have a 5 speed 900 Ford that I took out from winter storage. Now the PTO grinds as I try to engage it. (even when the engine is idling) I can shut off the engine and then I can engage the PTO but is seems stiffer that I remember. It's still cold here today as being in the 20's. Could this be due to stiff oil? The oil is a golden color (not milky at all) but I don't know what weight it is as I purchased the tractor last spring. If not the low temp and oil what would cause the grinding to start now? The tractor does not grind when shifting gears.
Also on the 5 speeds 900's. Do all of this variant have true live PTO? Or do some have the 1/2 clutch down to stop the tractor?
Dave
Dave
