1710 hydrolic fluid in engine.
hug3555
New User
Tractors been sitting for a while. Replaced fluid and filters, cranked it up and after about 10 minutes started porinf fluid out of the valve cover vent pipe. I took a sample of it, it was hydraulic fluid. Any idea how this can be.
The hydraulic pump is external and the plumbing to the back of the transmission.
I picked up a new seal from NAPA, installed it and it did the same thing.
The seal is being pushed to the front of the pump causing it to leak. Is there any adjustment that can cause this or is the pump body just worn out?
