fixitforfree
I replaced my faded 4630 instrument cluster with a new aftermarket unit. My temp gauge worked in my old unit but will not register at all in my new unit. I know the correct wire got hooked to the terminal at the temp gauge. With an ohm meter what how do I check to confirm
1) my sending unit is good (should be as I did not change this and it worked with old unit)
2) gauge is good
I assume some ohm readings associated with these can be read and confirmed. Thanks for any instruction.
2) gauge is good
