ford 545a loosing power
hey guys, i have a ford 545a with a box blade and bucket.
over the last year or so ive been having this problem where it seems like its been loosing power more and more. now its too the point where even in 1st gear trying to use the box blade its just boggy and can hardly pull. ive replaced the injectors,fuel filters, ive also pulled the tank and cleaned it. im wondering if anyone has run into this problem? bad injection pump?
Are you getting smoke &/or blowby? Where did you get the injectors? Some places sell "will fit" injectors, but they may not have the correct nozzle size or pattern. What is your compression?
Diagnosis is cheaper than parts.
no blow by, no smoke, injectors where from the local ford tractor dealer, i have not checked compression but the engine is only 3 years old, we had a hole/crack from the coolant passage to the oil pan :roll:
Some other things to think about.
Fuel return line from injection pump to tank plugged.
Torque Converter damaged.
Injection Pump damaged.
Injection Pump timing incorrect.
