old alternator went out on diesel 6610 and replacing it with a 3 wire gm alternator. could yall tell me if i understand the wiring correctly.
the #1 terminal will be a wire going to the on side of the key switch with either a diode or idiot light in it. (which do yall prefer?)
the #2 loops down to the bat terminal
the wire from the bat terminal goes to the starter terminal where the cable hooks since i am putting a volt meter on the dash.
and as far as hooking up the volt meter i just need a wire from the on side of key to the plus terminal of the gauge and a ground wire from the neg. termianl to a good ground correct?
thanks for the help again guys
