JWA
Last used the 3pt lift with forks to log pine logs last fall, logs were 9 ft long and ranged from 18" to 28" diameter. It had the front end floating a little but lifted them with no problems. Cranked the tractor today and the lift will not even attempt to raise, position or draft. Fluid level is full. Any ideas?
