The tractor will not go into the calibration mode. It flashes a "D" where it should be flashing "cal". The tractor is at operating temp. I have the
parking brake on. I have the key off, hold the shifter to the left. Then I start the tractor while holding the shifter to the left in neutral. I hold it for
about 5 seconds then it displays "d" next to the gear symbol. As soon as I let go of the shifter the "d" goes away and it just shows which gear
the tractor is in. What does the "D" mean? I don't see anything about the D in the service manual. I just had the speed block taken off and the
latest software put on the modules by Ag Express. That is the reason for the recalibration. It seems to be shifting harder than it should between
9-10. Thanks for the advise.
