Keith Molden
Would anyone by chance have the part # for the rear pinion bearing for a Ford 960. I finally felt good enough to finish pulling the tractor apart and the rear bearing on the pinion (NOT THE PILOT BEARING) was the only thing wrong with it and what caused it to lock up. By rear bearing I mean from the front of the pinion shaft there is lock nuts, then a bearing, then toward the ring gear is another bearing (this is the one I need the # for) then on the extreme end at the ring gear housing there is the pilot bearing. As usual, I had to cut the inner bearing race off and I cut the numbers. It is a Timken bearing and the dealer wants $87 and change for it. I know they are out there cheaper if I can get the part number. Keith
