rear remote
i have a ford 600 that i ant to add rear remote system for a external hydrulic cylinder and need to find out what kit i can but and also need to be able to use the rear remote system as well as the 3 point lift arms at the same time..can anyone help with this issue i found a part on yesterday tractor site part # S.68981 but they can answer my queston if that kit will let me operate the remote cylinder and my 3 point at the same time
The number you listed is a Sparex number. The company is based in Wales, but appears to a US (wholesale only) dealer/distributor. You might ask them.
http://us.sparex.com/remote-hydraulic-control-kit-68981.html
Plate under the seat with a hyd lever on it. Sometimes some of the parts are on your tractor already, got any pics?
Paul
That is the correct kit for your machine, YT must source the kit from Sparex as that is the Sparex part number. The plate on the top front of the lift cover to supply oil to a remote cylinder
to be run with the 3pt lever would have had a knob, not a lever. Knob one way supplied oil to 3pt, other way oil went to remote hose. That kit allows both 3pt and remote to be used at the
same time. decent price also as we used to get $250 for used valves off salvage tractors. Same valve fits from 1955 up into the 1980's.
There are several styles of valves that will mount on the top
cover, at the front, under the front edge of the seat.
Both single and dual remote valves for two or four hoses.
These let you use both 3 pt and remotes at the same time.
The one you listed would too. On the other hand, a selector
valve installed in the same location is where you get the use
of one or the other at a time. Some used ones I've bought:
Ford Dual remote for a x00/x01 shown mounted on my 3000
Tisco dual remote missing a handle
Single remote with handle made for x000 style tractors. Works on x00/x01 too.
(quoted from post at 15:46:03 02/21/18) That is the correct kit for your machine, YT must source the kit from Sparex as that is the Sparex part number. The plate on the top front of the lift cover to supply oil to a remote cylinder
so i can use both 3 point and remote cylinder at the same time?
(quoted from post at 19:57:39 02/21/18) Not a bad price
Untitled URL Link
They are not priced badly. I don't have one like that.
I was thinking the handle sticking out the front might get kicked
and broken when getting on and off the tractor. The ones on my
Ferguson stick out the front and they're right in the way.
Benthereford,
Short answer is YES.
An explanation:
This is a hydraulic system that is routed from the pump to the top cover then to the 3 point.
So if you mount a valve on the top cover that diverts all the oil pressure to say a backhoe that dumps what it does not use (and what it does use) back to the hydraulic sump, there will be no oil going to the 3 Point. I think these are called diverter valve.
If you mount a "normal valve" like is listed, it will get oil pressure FIRST, Then the 3 pt will get pressure.
For an example, When I used a 711 dump bucket loader on the front and a Slip Scoop on the 3 point, if I dropped both to the ground, then raised both, the bucket came up first then the 3 point.
If I pulled the 3 point lever then a couple seconds later raise the bucket some and let off, the 3 point would start to raise, then the bucket would move then when I stopped it the 3 point would finish.
Most of the time, the 3 point was up and it stayed up as it should. I could use the loader and all was well. The Slip Scoop was loaded with dirt to add weight to the back of the tractor.
Clear???
HTH
Keith
Here's a picture of the control valve on my TO-35 Deluxe.
You can see why it would be in the way getting on and off.
Not so bad in the summer, but with boots on in the winter its a bear.
This is a dual remote valve, but I only use one side of it.
