Ford New Holland TS135 serial#
We bought a TS135A that had a fire. Cab and hood are burned. I realize this is a little new for this forum but thought maybe somebody would know. I assume wherever the serial/vin plate was is now gone. Is there a spot where this number is stamped into the frame or someplace? Thanks!
Not sure about the TS series, but older large frame tractors had model, tractor, and unit numbers stamped in the center housing on a horizontally flat spot above the PTO.
Well, TS series tractors were stamped in the front bolster... flip the hood up and have a look on that front rail. Not sure if the TS-A is stamped there or not but it doesn't seem unreasonable to look...
Rod
