ejr-IA.
My friend bought a 6000 commander diesel ford Sat.bought it reasonable room for issues .Problem with it is erratic steering,no brakes,and 3pt will not lift can you help us out with the problem.The SOS works motor runs good descent over all. Need ideas thanks.
Just a *wee* bit more detail would be nice. Your request would be like telling the doctor over the phone that you don't feel good and expecting an instant, accurate diagnosis.
I agree with Shaun check hydraulic oil first. Steering is a separate pump from the rest but sucks out of the same reservoir. If that doesn?t fix the brakes and hydraulics there is a valve under the front that kicks the pump in and out because of the accumulator system. They can stick and the pump just bypasses. My 61 will act up after it sits over the winter.
