Factory color of Ford Model 640 Tractor
What year is it, and what was the original color scheme?
That S/N 119250 was used in May of 1960 which would make it a 641 with an all red hood and gray only on the grille, fenders and wheels.
That serial number could also be a 1957 hundred series serial number. They started over at 1001 when the '01 series came out.
If it is stamped "640" above the serial number then it is a 1957 640. If it is stamped "641" above the serial number then it is a 1960 641.
Ford started a new series of serial numbers with the XX1 tractors. A
640 with serial number 119250 would be a 1957 model. This site has
serial number reference for both the XX0 series and XX1 series. Below
is the link for the XX0 series.
Ford XX0 serial numbers
