TractorLinks.com
Order Ford 640 Parts Online
Ford 640 cracked front Axle
nashranch
02-14-2018 08:24:39
Taking apart the front end on my 640 to try and repair the front axle that I discovered was cracked. Having a hard time unscrewing the pivot pin..soaking now in PB blaster. May try a little heat after while. Can this axle be welded ?
nashranch
02-23-2018 17:15:57
 Re: Ford 640 cracked front Axle in reply to nashranch, 02-14-2018 08:24:39
Well greased and put back together...new axle pin and newly machined bushing to fit axle and pin
nashranch
02-15-2018 18:05:31
got a good weld with 7018 rod today
I'm happy... it should hold up jut fine
Ultradog MN
02-16-2018 12:28:53
 Re: Ford 640 cracked front Axle in reply to nashranch, 02-15-2018 18:05:31
Looks good.
Cheaper than a used axle too.
nashranch
02-14-2018 19:55:22
you're right Royse, My pin did look like this
http://www.yesterdaystractors.com/Ford-3000_Pin-Front-Axle_C5NN3127B.html
and the bushing measures up to what mine measures..cool I GOT A 3000 FRONT AXLE
http://www.yesterdaystractors.com/Ford-3000_Axle-Pin-Bushing_C7NN3153B.html
nashranch
02-14-2018 19:39:21
I know what you mean Royse, it doesn't match up with the New holland parts breakdown for a 640. The pin measurement you see in the pic does match the pin in the YT parts.
http://www.yesterdaystractors.com/Ford-600_Axle-Pin-Threaded_NCA3127A.html
What bothers me is the measurement I get on the inside of the front axle. I don't see a replacement bushing that matches my measurements. Not even close
http://www.yesterdaystractors.com/Ford-600_Axle-Pin-Support-Bushing_2N3039.html
Royse
02-14-2018 19:20:40
Glad you got it apart, now to get it back together.
What's throwing me is that pin. It just doesn't look right to me.
It looks like the axle pin on my 3000, not my NAA or earlier.
It's been too long since I did my 640 to remember what it looked
like, but I'll take a look through my pictures and see if I can find it.
nashranch
02-14-2018 18:31:13
Well its apart finally in pieces. Ended up cutting it out with my grinder and a thin cutoff wheel. The center pin was totally bonded to the outer sleeve so I was never gonna get it apart by unscrewing it. Now to weld up the axle and order in new parts to remount it.
Not much threads left in the Bolster
nashranch
02-14-2018 16:10:58
Now Royse... threads are still visible but the whole thing just spins. Pretty sure the threads are stripped out. I have tried heating and beating at this point... does no good. Cutting torch is probably the next step
I'm open to suggestions
Royse
02-14-2018 15:40:55
The earlier tractors had a pin or a bolt holding them in with no
threads to back them out and nothing to get a hold of to pull on really.
So what I did with those is take the bolster off the front of the
engine and drive them out from the back side once I got them
to turn a little side-to-side.
If yours has backed out so that the threads are clear, maybe you
can do the same thing with it now that it's loose.
nashranch
02-14-2018 13:30:30
Not sure if theirs a sleeve on the pivot pin but maybe the threads on the end of the pin have stripped out so I'm just spinning in one spot. Not sure, It screws back in ok
nashranch
02-14-2018 13:19:49
I finally got the 1 5/8" nut loose on the pivot pin and backed out a bit till it ran outta threads but there seems to be a sleeve on the pin that is of course rusted on so it all just turns but won't back out. been heating and beating but she is a no go for now. any suggestions out there??
riveroadrat
02-14-2018 11:22:29
I had a pin that was a bear. I actually welded a piece of 1/2" thick wall tube that was cut to fit in the slot to the pin. After that it took a pry bar about 4' long with heat to move it. It came out hard most of the way. Let it cool a little after heating.
Roger in Iowa
02-14-2018 09:51:51
Do you have a loader on the tractor? If you do, replace the axle.
nashranch
02-14-2018 09:01:50
Thank You UD
Ultradog MN
02-14-2018 08:34:07
Those are made of a good drop forged steel.
Yes, they can easily be be welded. Vee it out good and fill it with weld.
I would use 7018 rod. No special pre or post heat needed.
