7000 utility weights front and rear
plow hand
Im looking to dress up my 7000 anyone have info on the style for the front and rear or part numbers thanks
Front could have wheel weights and/or 75# suitcase weights. The pillow weights will also fit, though they aren't shown in the owner's manual. Which rear wheel weights you need will depend on what style wheels you have... stamped oor cast center, power or manual adjust.
No numbers on the wheel weights on my 7000. TW35's wheel weights have a part number cast into them, but not even close to the same. You'll probably have to measure between mounting holes and go from there.
I'll try posting a picture if my 7000's weights in the photo gallery. There are two styles that will fit if your wheels are like mine - the ones o have, or a thinner, larger diameter one.
