jimf in mo
How much oil goes in a Sherman combination trans? I have found a lot of info on it but cant seem to find oil capacity.
A little info
Its out of a 64 4000 4cyl.
its a 4th generation Sherman made by Ford
Its serial # is 78206. on Smith old tractor they say 75000 is highest serial # they seen so this could be one of the last ones made.
I am going through the tractor and as long as the it split I want go through thing and always replace trans shaft seals. not worth going on the cheap for the amount of work I'm doing
any help on oil capacity will be appreciated. Also anybody know a source for the shifter arm grommet.
A little info
