I was hoping someone would be able to help, I have a Ford 5000 that I cannot keep coolant in the radiator. When the tractor gets warmed up, coolant will come out of the overflow tube by the radiator fill cap and cause the tractor to overheat after time (I can then go back and add about 3 gallons of water back into the radiator). I do not see water going anywhere else, (i.e. the oil). The only other thing that I can think of that could be related is that I have a decent amount of blowby from the tube connected to the valve cover along with an oily grey sludge dripping from the tube.
Thank you for your help
Justin
Justin
