boxrucker4
New User
Working on a 1971 Ford 3000 with a 3pt that doesn't work right. It'll lift the arms about an inch or two but then stop. Hydraulics work great and test out around 2500
psi, so the pump is good. Had the top cover off, and everything looks nice, filters are clean, almost no sludge, and the oil was decent too. Cylinder looks good with no
scoring. I went through every check valve and safety valve to make sure there wasn't any debris in them. I put the top cover back on, and its still having the same
issue. Those two inches that it does raise, are fast, and not sluggish or anything. So now what?? I was assuming something is out of adjustment, but no matter what I
do, they still won't raise properly. Any advice would be greatly appreciated. Thanks
