Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Order Ford 4000 Parts Online
Re: Old style 4000, 4 cylinder diesel - injection leak off
TinCan
02-08-2018 16:16:03
Question. When I removed the timing cover on my pump a bunch of fuel ran out. It had sat for 15 yrs before I got it, and I don't remember if the fuel was shut off. Is it normal for fuel to run out, and if so, how much?
Sorry for the Question on your thread.
Thanks, Pat
Tom in TN
02-08-2018 17:23:52
 Re: Old style 4000, 4 cylinder diesel - injection leak off in reply to TinCan, 02-08-2018 16:16:03
Pat,
Your question is part of my dilemma. It was my understanding that with the fuel valve on the tank turned off, when the timing cover is removed, less than a gallon of fuel should run out. The filter will partially drain and the fuel in the injector pump will drain, but it was my understanding that amount is all that should drain out. For whatever reason, multiple gallons came out of my pump. That's when I disconnected the injector leak off line from the pump and ended up draining the whole tank of fuel into a couple of gas cans.
I don't think that is normal, but I'm not sure at this point.
Tom in TN
