TractorLinks.com
Show Parts for Model:
1985 1910 4wd tractor 3 pt hitch
mcc2
02-08-2018 07:56:53
Hi all I need to the forum and hope you will be able to help me.I purchased in 1985 Ford 1910 tractor with the backhoe on it. It has 800 hours on it. The backhoe has been on the tractor since it was new. The brackets that hold the backhoe onto the tractor were bolted and welded. I had the tractor worked on so I can remove the backup. My next challenge is to set it up with a three point hitch it seems that it is going to be hard to find parts for it can anybody give me suggestions as to where I can find parts for the three-point hitch. I need everything. Thanks for your help will.
CJinMI
02-09-2018 13:10:06
 Re: 1985 1910 4wd tractor 3 pt hitch in reply to mcc2, 02-08-2018 07:56:53
Busted one for sale. Tractor Talk, part way down,
titled ooooo,killer deal.
(don't know where you're at).
Craigslist,ebay, Weavers compact tractor parts, West Kentucky tractor parts, 1 I don't remember.
Sean in PA
02-09-2018 06:15:20
That is just a generic external kit for the arms and linkage.
I don't know exactly what the OP's tractor has on it now, but he said "I need everything", so if the tractor truly does not have a 3 point lift then that will not give him a working 3 point system. He will need the hydraulic top cover hat has the lift cylinder, touch control handle and control valve, etc. If it has the hydraulic top cover and is only missing the external arms, then yes, that kit would work.
JoeM(GA)
02-08-2018 15:31:27
give these folks a call, I bet they can help you. they have new stuff and also salvage
JoeM(GA)
02-08-2018 18:47:06
 Re: 1985 1910 4wd tractor 3 pt hitch in reply to JoeM(GA), 02-08-2018 15:31:27
here's another I just ran across -
Sean in PA
02-08-2018 08:19:32
I think your only chance is to find a salvage yard that has one to get the parts from.
