TractorLinks.com
Show Parts for Model:
Is the 850 and 851 the same tractor with different engines?
Off Road SHO
02-06-2018 07:17:16
I am about to get another Ford, this one an 851 with a Dearborn grader front end. It looks pretty much just like my 850 gasser.
Tom
Sean in PA
02-06-2018 14:14:12
 Re: Is the 850 and 851 the same tractor with different engin in reply to Off Road SHO, 02-06-2018 07:17:16
In reply to your query in the subject of the post... No, they are slightly different tractors with basically the same engine, unless the 851 has a diesel engine, in which case the engines are different but based on the same basic design.
Sean in PA
02-06-2018 14:11:18
The grill should look different.
Destroked 450
02-06-2018 10:51:27
850 is part of the -00 series built 1955-57
851 is part of the -01 series built 58-62
Both are the same basic tractor with 5 spd trans and trans pto.
Kirk-NJ
02-06-2018 08:00:03
 Re: Is the 850 and 851 the same tractor with different engines? in reply to Off Road SHO, 02-06-2018 07:17:16
Trans housing and rear/hydraulic housing are different. Depending on the year it might have the beefed up rear end. Hood and fenders are different. Depending on the year it might have a better hydraulic pump and larger carb. Other than that pretty much the same
Off Road SHO
02-06-2018 07:36:04
Thanks
Dollar Bill
02-06-2018 07:29:57
The two are virtually the same.
