Got a '64 4000 Sos. Going to convert it to 12v-3 wire. found a few wiring diagrams but not very detailed in hooking up the 2 warning lights that I have.
1- does the transmission pressure switch just run from the switch inside of the transmission through the light to a hot spot when the key is on?
2-does the charge warning light (hooks in Field wire) run through the light and to a hot spot when the key is on? or does it need a different type of light?..
3- is the wire really needed that runs off the ig terminal on the starter relay.
Thanks for the help.
