need help on 3000
maybe... its the correct length,, but the front mounts will be different. With slight modification of the mounts it will fit... Then there is mounting the hydraulic pump that is more of a problem, but you could run the loader off the tractor hydraulics.
(quoted from post at 19:15:22 02/04/18)
Larry, to add more.. lots of 4610 loaders, the rear mount was bolted to the transmission and not the rear axle. On the original 3000 loaders, mostly the rear mount bolted to the rear axle. And the front mount on most 410 loaders bolted to the side of the bolster or front is a qd... the 3000 loader had have a different mount as the front bolster did not have those mounting points..
You will probably be modifying the mounts and again, the 4610 would run a loader fairly good off of tractor hydraulics where the 3000 relied on the optional front mounted pump, which added to the front loader mount design. I have see many tractors where the loaders where the mounts were made and they work out fine.
