Ford 3400/3000 coil resistor issue..
greymond
With the coil below do I need a resistor? If so which wire gets the resistor? I have a ford gas 3000 one wire from the coil to the solenoid, one wire goes from the distributor to the coil and one wire jumps across the engine to the generator.
thanks
Resistance wire in tractor as from factory (in the one coming from area of generator). All well.
