Snowplow on CL
Kirk-NJ
This is a pretty good deal for someone near long island NY. Missing the rear bracket but not hard to piece something together using a drawbar and a pulley. Could even use on 9n/2n/8n by making a
bracket out of angle iron. No connection.
Snowplow
That's a bargain.
Would be tough to put on an N though since they dont have any place to mount it under the transmission. Would not be hard to convert it to hyd lift too.
Tha blade is universal and will pin onto any of the Dearborn or Ford frames all the way into the 70s.
It's pretty easy to mount to and 8n. Drill two holes in the front bracket and make up a piece of angle iron and bolt to the bell housing, much like the one arm loader on the 8n. A couple of long grade 5 or 8 bolts. The hydraulic mount wouldn't be that difficult either just plug on side on the piston and run off the test port for pressure up and gravity down.
<a href="https://imgur.com/iYZDdOY">
iYZDdOYh.jpg" title="source: imgur.com"
</a>
Here is what I rigged up with a drawbar a few pieces of angle iron and a pulley to raise on the three point. I did find the right bracket a couple years later. Just posting in since there's no rear bracket with this plow.
<a href="https://imgur.com/WQchdJG">
WQchdJGh.jpg" title="source: imgur.com"
</a>
Here's a shot of the bracket I made to carry the back of the frame.
<a href="https://imgur.com/8RiHmCp">
8RiHmCph.jpg" title="source: imgur.com"
</a>
