Ford 730 loader relief valve setting
riveroadrat
Does anyone know the procedure for setting the relief valve on a 730 FEL valve? Where to plumb in a gauge to check the relief pressure? Also any thing that would give me a problem changing the spool seals. Also is there a reason why the check valves would leak? My cylinders are good. Pics are up. On the bottom of the valve there is a port opposite the pump inlet connection. Will I need to remove maybe one of the lift lines and plumb the gauge inbetween to check what pressure the relief valve is opening at?
