koyker 500 on 6610
found a koyker 500 for sale local for $1900 has brackets but havent checked to make sure they will fit yet, but they had several holes in brackets so looked somewhat universal. i think the loader might be a hair on the big side for this tractor but think it will be ok what do yall think?
also my tractor has the 2nd pump mounted on the engine what kind of gpm should i get at the loader? thanks
That loader is rated for 60-150 hp tractors, you'll need loaded tires and weights.
Make sure the brackets are for your tractor or you have to do a bunch of fabricating.
For general use the smaller model 310 would be my choice.
It's rated for 45-90 hp tractors.
My has a Koyker 550 for his 7710, but its slow because he doesn't have a auxiliary hydraulic pump. He paid $3500 way back when he bought it, for a front end loader you need at least a 10gpm pump so it will work faster. A industrial tractor will something around a 20gpm pump if it came with a loader on it.
