Leaky Loader tilt cylinder
nashranch
I have a Superior 221C loader on my 1955 Ford 640 tractor. The front is leaking pretty bad. I've been trying to find a source for parts and am striking out so far. Anybody know a place where I can get a rebuild kit? Pictured is the cylinder fully extended. Approx 16' stroke..1 1/4" bore
I removed that leaky cylinder this evening and took it apart...really quite simple design...hopefully I can find parts for it.
Brand of cylinder would be nice if anybody knows what they are
A few pics
I couldn't find any places with Superior loader seals and kit form
either. However your piston seals are "vee" packings (most likely the
gland as well). If you go to Baum Hydraulics and download catalog
section G you should be able to match them up. You should be able to
find misc other seal parts as well such as O-rings and rod wiper. The
trick is to learn the "system" - identifying and accurately measuring.
You can then take the catalog numbers and place an online order.
Alternatively you can go to your local hydraulics or seals business
and see if they can match the seals.
Baum catalog download
(quoted from post at 05:23:07 01/24/18) I couldn't find any places with Superior loader seals and kit form
Thanks Andy
