(quoted from post at 05:23:07 01/24/18) I couldn't find any places with Superior loader seals and kit form
either. However your piston seals are "vee" packings (most likely the
gland as well). If you go to Baum Hydraulics and download catalog
section G you should be able to match them up. You should be able to
find misc other seal parts as well such as O-rings and rod wiper. The
trick is to learn the "system" - identifying and accurately measuring.
You can then take the catalog numbers and place an online order.
Alternatively you can go to your local hydraulics or seals business
and see if they can match the seals.
Baum catalog download
