Hi guys
It's been awhile since I been on here super busy.I got a question about my lift as most know the tractor was restored completely I cleaned everything very well and replaced the oring on the piston the lift works and does not leak down. The problem I am having is the lift does not move until the lift handle is almost to the top. Now if I pull the draft control lever up horizontal the lift will start lifting when I slide the lever up about 1/2 way. So I'm guessing I need to make an adjustment anybody know the adjustments I need to make. Thanks
