Looking through some of the archives, I see this is a popular topic, but I haven't been able to find exactly what I'm dealing with. Because of the fuel shutoff screw working it's way out (probably due to a bad rivet/pin) I am trying to replace the entire fuel shutoff valve. I assumed I'd be able to just pop the old one out, and replace it with the new one, but I don't have enough clearance above the valve cover to pull it all the way out (see picture).
My first thought was to remove the valve cover, but I don't think I have the clearance to do that either. So, I proceeded with a new plan to remove the tank altogether, but quickly learned that removing the hood to even get to the tank is turning into quite the project (numerous bolts/screws which are tough to access, a wiring harness attached to the headlamps which are attached to the hood, etc.).
So now I'm at a standstill, thinking there's got to be a better way to replace this little valve. Has anyone done this before? Do I really need to remove the tank in order to accomplish this??
I'd appreciate any help at all, thanks!
Tom, 801 (861) Powermaster
<image src="http://forums.yesterdaystractors.com/photos/mvphoto9443.jpg"/>
