Sean in PA
Over on another tractor board someone just pointed out a drawing in the Ford factory service manual for the 1965-1974 thousand series tractors. In the Electrical section, on page 46, it is figure 56. It shows two different setups for the wiring to the coil primary from the key switch. One setup has the resistance wire and the starter bypass wire and it says those are for the 5" coil, and the other setup shows a non-resistance wire and no bypass, and it says that one is for a 5-1/2" coil.
Does anyone know which tractors got the 5-1/2" coil that didn't use the resistance wire? was it on certain models, or after a certain date on all models? I can only find reference to a single part number for the coil on the parts site, and it looks like it's for the one that uses the resistance wire.
Has anyone ever seen one that came from the factory with the 5-1/2" coil and no resistance wire?
