Hello,
I think the timing is off on my 1955 Ford 860 so I plan to check it tomorrow. I've ready many posts about static timing so I understand the process just fine. However, the original Ford shop manual and the I&T shop manual give different degree settings so I just wanted some clarification.
The Ford manual says the index mark should line up with 4 degrees on the flywheel. I&T says it should line up with 26 degrees. I&T calls this the "fully advanced timing" but the Ford manual says it would be 24 degrees at 2200RPM, not 26. Which is correct?
My main question is: If I'm static timing my 860 with the engine off, should the index mark line up with 4 or 26 on the flywheel?
Thank you for your time.
-Mike
-Mike
