Shuttle check valve T part number and plumbing
MNfarmer
I've got a ccls joystick valve ordered for
my 7710 series 2 and I want to double
check on the plumbing. I believe the
pressure line to the valve would be
plumbed into the steel line between the
remote valve and the priority valve and
the shuttle T plumbed into the small steel
line coming out of the back of the remote
valve correct?? Where is the best place
to plumb in the return from the loader
valve? I've also read that there's more
than one shuttle T available, which one do
I need? I'll be buying it through NH.
Thanks!
Awesome, thank you for all the help Bern!! So they're plumbing the return from the loader valve into the filler pipe at the rear that the remotes dump into correct?
Since it's not a constant flow, 1/2" hose is sufficient. Yes, return can go into the back filler neck. There is a plug in the filler neck near the opening that you can tap into.
Link below is another helpful image. More like it can be found under "7411 loader" which was the loader for the 7740 and similar tractors.
More plumbing
Flowfit Hydraulic Shuttle Valve 1/4" BSP V0666 Free UK & EU Delivery
Item # : 251550237926
End time: Wednesday, Sep 03, 2014 07:05:27 PDT
Sale price: GBP 17.47
Seller: flowfitonline
Case opened: Tuesday, Sep 02, 2014 00:02:24 PDT
Case closed: Tuesday, Sep 02, 2014 05:21:52 PDT
View purchased item
Thanks again Bern! So for the supply and sensing lines, do you cut and T into the middle of the line or put the T's at the current connections where the lines meet the valves?
