Hello,
After less than 5 hours of run time, my electronic ignition failed. Pertronix sent a replacement at no cost and it has been installed. I also have a 3 ohm Pertronix coil so the external resistor (small white rectangular block) has been removed. It was probably a faulty part but I just want to be sure my 860 is wired correctly so I'm not sending too much juice to the electronic ignition.
Below is a crude diagram of how everything is connected, does it look correct? Thank you for your time.
-Mike
-Mike
